373
12
This picture shows electrical crews working in a "foreign" country. [This message has been edited by Joe Tedesco (edited 07-14-2002).]
Occasionally, it does work both ways. [This message has been edited by Bjarney (edited 07-03-2002).]
it simply takes enough to be 'safe'
Joe,
Here in Northern NJ, I believe the power co. requires for 2 men per truck. 1 in the bucket and 1 on the ground at a minimum. They will send out more than 1 truck o a scene of an accident to try and get things repaired quickly. However with de-regulation and with the companys required to make a profit, The power company has cut back on man power. What use to take an hour to fix, now takes 1/2 a day. What use to take 1/2 a day now goes into 2-3 days. There just isn't enough manpower here anymore to handle the problems. The power co. has downsized their people, yet they turn around and hire all sorts of sub contractors. I have seen utility crews from PA., Mich., NY., Ohio, and several other sub contractors from out of NJ working here.
Caper
God bless the TVA, and public power around here. Most evertyhing in our area is still public utilities, non-profit, and non-cut corners, power is still dirt cheap and plentiful. Thanks Mr. Roosevelt , daddy got job with TVA we bought a washing machine and then a Chevrolet.
Lighting the way
Over here Electricians are not allowed near the lines, apart from pulling HRC pole fuses. I am a Faultsman, I am registered both as an Electrician and a Line Mechanic, but I can see where you guys are coming from, but I did notice, the very heavy insulation on the lines in the picture. Over here, we work on 11kV,33kV and 66kV lines, every thing is bare, if it is around people, it is underground, but if it is out in the rural areas of Canterbury, you have to turn off the juice.
