Smoky?
by gfretwell - 06/09/23 11:23 AM
Historical NEC Info
by gfretwell - 06/03/23 02:15 PM
Water heater 208 vs 240
by gfretwell - 06/02/23 06:26 PM
Help Finding Fault
by gfretwell - 05/30/23 10:05 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 14 guests, and 11 robots.
#102822 01/01/07 08:32 PM
RobbieD Offline OP
Hi, this is a question for guys in Ontario. I just moved to Ontario this year from out east so I am a bit unsure on the answer.
My brother just bought an older house that has 4 circuits that are still knob and tube. He wants to get a homeowners permit to change these circuits to loomex. I would of course help him with this since I am an electrician and he is my brother.
Since there will be no messing with the service, could he just change the circuits that are knob to loomex and thats it?
or
Would he have to rewire to make the whole house up to todays standards? ie.arc faults, smoke detectors, splits.
Also, is it a requirement to use the coloured loomex for identifying the circuits here in Ontario?
I ask because in NS if you change the service you have to bring the whole house up to standard. But here there is no messing with the service so I thought I would check.
Thanks!
[This message has been edited by RobbieD (edited 01-01-2007).]
#102823 01/02/07 01:12 AM
How did he get a reasonable insurance rate for a house that had K&T wiring?
You can ask the ESA directly for your questions:
www.esasafe.com
#102824 01/02/07 11:41 AM
The NFPA has information for aging wiring.
#102825 01/02/07 04:44 PM
You do not have use the color coded cable.
If start rewiring a room then you must bring the room up to code with the proper number and placement of receptacles, AFCI, GFCI etc.
#102826 01/02/07 06:00 PM
RobbieD Offline OP
Thanks. I know I could ask ESA but I figured I would use the forum. Doesn't seem to be much action on the Canadian section here so I posted a question to get things going.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
CDS
CDS
Nicholson Ga
BigB 6
307,256 Are you busy
235,222 Re: Forum
219,314 Need opinion
