Photo of the Week:
Mouse on a Bus
Mouse on a Bus
0 members (), 111 guests, and 26 robots.
#102074 12/09/04 02:03 PM
I,m changing an old industriul unit into three lofts.I,m using the existing incoming 600v fusible disconnect which feeds a 225kva transformer which then feeds a 800amp metering section.My question is do I need a disco in between the transformer and metering board or does the 600v main disco cover this.
#102075 12/09/04 03:11 PM
The main disconnect should be fine until you get to the 800-amp 208-volt splitter.
Then you will have to install disconnect switches for each separate service, with or without utility or check meters, for the different lofts.
Tony Moscioni
Electrical Inspector
Electrical Safety Authority
#102076 12/10/04 08:29 AM
Thanks Tony thats what I thought.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
HappyElectrician
HappyElectrician
Penn USA
340,313 Are you busy
265,711 Re: Forum
246,717 Need opinion
