This is your chance to comment on Canadian Electrical Code Part 1 proposed revisions and interpretation issues (subjects) for the 2006' code cycle.
The Part 1 committee refers to each proposed revisions or interpretations as "subjects". Each subject is assigned a subject number e.g. "Subject No.3165". When I receive a Subject I will forward each as an "Adobe Acrobat PDF file".
Please reply with comments regarding the attached Part 1 Subject by November 01st 2004'. When replying please indicate agreement or disagreement with the Sub-committee's recommendation
Tony Moscioni
Electrical Inspector
416.991.4145
Subject 2554 - 120KB PDF
Exemption from Certain Requirements, Rule 50-003
Subject 2797 - 108KB PDF
Batteries, Rule 50-XXX
Subject 3106 - 84KB PDF
Changes for Distributed Generators, Section 84
Subject 3106 Attachment - 159KB PDF
SECTION 84 PROPOSED RE-WRITE BASED ON MICRO-POWER GENERATION TASK FORCE RECOMMENDATIONS
Subject 3119 - 82KB PDF
Use of Arc Welding Cable, Rule 50-014(2)
Subject 3120 - 72KB PDF
Connection of DC Equipment, Rule 50-020(1)
Subject 3121 - 84KB PDF
Disconnecting Means, Rule 50-012(3)
Subject 3159 - 94KB PDF
Raceways Used for Cable Management, Rule 56-212
Subject 3177 - 170KB PDF
Adequate Ventilation, Rules 18-002 and 18-006, Appendix B Notes to Rules 18-000,
18-002 and 18-006
Subject 3189 - 89KB PDF
Overcurrent Protection of Transformer Circuits, Rules 26-252, 26-254, and 26-256
