0 members (), 510 guests, and 23 robots.
#101854 10/26/03 03:36 AM
Does anyone know the reason and meaning behind the "with and without jacket" for table 6 of the C.E.C. part 1?
#101855 10/26/03 11:42 AM
deleted by me
[This message has been edited by dougwells (edited 10-26-2003).]
#101856 10/26/03 02:03 PM
I was told that some RW conductors were available with a jacket around the insulation, making the wire bigger in size (for a given AWG conductor size). Hence requiring more space in the conduit. Although I have worked with unjacketed conductors, I have never seen a jacketed conductor. I was told "the difference is obvious. Does anyone have a photo of a jacketed conductor
#101857 10/26/03 09:54 PM
I was under the impression that it was some-what thinner due to the nylon "jacket", I'm not sure if that is what they are stipulating? This nylon coating, from what I am told is for anti-abrasion. Is this the "jacket" that Table 6 is refering to?
#101858 10/26/03 10:22 PM
The dimensions given in table 10 indicate thicker. (note asterexes and daggers). What does the jacket look like? What is it made out of? Why would you use a jacketed conductor? I don't know!!! If someone out there knows, please help?
#101859 10/28/03 12:36 AM
I remember a sample in school.
It was just a layer of cellophane on the outside of the insulation, similar to the one that comes around Teck.
#101860 10/28/03 05:34 PM
F
The_Original_Modifier,
Here ya go http://www.nexansenergy.com/egy/tecdoc/1.htm
#101861 10/29/03 07:53 PM
Thanks, Frank.
#101862 10/30/03 03:47 PM
Thank you to all who replied, you've been a great help.
