Countertop Receptacles
by HotLine1 - 05/18/23 12:40 PM
Windows 10, who's upgraded?
by LindaParker - 05/15/23 04:29 AM
We can all breathe easy....
by gfretwell - 05/11/23 01:00 PM
What's your Hobby?
by gfretwell - 05/11/23 12:57 PM
Your favourite food?
by renosteinke - 05/10/23 09:28 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 60 guests, and 17 robots.
Are AFCIs required by code in Canada?
If so, in what locations or under what circumstances?
dunno,
but seeing as we in Vermont will have an AFCI for 75% of our circuits, you'll not need go far to fetch 'em.
I've been looking around for them up here (now that I know what they look like-a GFI CB.) But I haven't found any. The last home job I did, the Elec. installed the panel and an assortment of normal CB's, so I'm assuming they aren't required (yet...).
(Sorry about putting the original post in the wrong spot!)
mickky,
You're Forgiven .. [Linked Image]
In the 19th edition of the Canadian Electrical Code (presently scheduled for release January 2002)will include the requirement for AFCI's.
Rule #26-722 - Branch Circuits in Dwelling Units)will include the additional clauses (f) and (g).
(f) "Branch circuits that supply receptacles in sleeping facilities of a dwelling unit shall be protected by an arc fault circuit interrupter"
(g) "For the purposes of Paragraph (f), an arc-fault interrupter means a device intended to provide protection from the effects of arc-faults by recognizing characteristics unique to arcing and functioning to de-energize the circuit when an arc-fault is detected"
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
MarkC10
MarkC10
CA, Inland Empire
Trumpy 11
306,970 Are you busy
234,859 Re: Forum
219,145 Need opinion
