0 members (), 239 guests, and 10 robots.
#1003 04/12/01 07:16 PM
wayne Offline OP
I Had a customer that called and said his fan in his bath needed replaced. After arriving I notice the switche/s were new. He said he replaced all the switches and Rec/in the house. The exhaust fan was on a 3 way switch. He had cross the travler/s.
He did say that he could not understand why once in a while the fan would work.
The bath has a door leading to the back porch. He was smart enought to reinstall a 3 way switch with same. He proably got that advice from a salesperson. Oh course we Know what was happing. [Linked Image]
any comments,
wayne
I did however take a look at the rec/ to insure that they were ok.
#1004 04/12/01 08:41 PM
I seen a do-it yourselfer change all the plugs in his house once, he was smart he checked that the power was off to each cct. But when it came time to turn the kitchen breakers back on he took out his main. Funny what happens when you forget to cut the tab on the plug with a split cct.
#1005 04/13/01 02:30 AM
What I've seen a lot is problems having to do with 3-way switches. Many people take out a 3-way and replace with a single pole. One of the 3 live wires usually goes on the green screw. For some reason the Breaker trips [Linked Image] [Linked Image]
#1006 04/13/01 06:48 AM
it's a living....... [Linked Image]
#1007 04/13/01 08:28 AM
I saw this recently, and, unfortunately the original was an older, non-grounding switch, so the grd was not connected to the new switches grd. term., only the red wire was. Luckily nobody got hurt.
[This message has been edited by Redsy (edited 04-13-2001).]
#1008 04/13/01 11:08 PM
Just finished a service upgrade where the owner did the interior wiring (he is an ex-home builder and cheap) and I did my standard test of all the circuits. After doing a visual check I then energized the breakers one at a time. Doing great till one of them tripped, so I rechecked the wiring and foun a light that had the hot and nuetral tied together. It happens. :.)
#1009 04/14/01 08:46 AM
I've had "tradespeople" (I don't dare call them electricians) install 4 ways instead of 2 pole switches on new projects. Makes for some interesting noises when the power is turned on.
#1010 04/14/01 04:12 PM
It really amazes me how many electricians and "tradespeople" as well as anybody who ever used a light switch never noticed that three and four way switches don't say "on" and "off" on the handle.
#1011 04/15/01 11:52 AM
don'tknow;
even better are some individuals assessment of electrical situations.
#1012 04/15/01 01:21 PM
and the interesting things they do with extension cords
