ShoutChat Box
Where is Everyone?
by JoeTestingEngr - 03/28/20 01:39 PM
Do you count seconds?
by HotLine1 - 03/26/20 11:36 AM
Mourning the death of this forum!
by HotLine1 - 03/25/20 06:45 PM
15 amp outlets removed due to cell phones
by grich - 03/23/20 06:59 PM
Trying times upon us
by grich - 03/23/20 06:53 PM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 4 guests, and 9 spiders.
Re: NEC Trivia Question??? #100545 12/03/06 12:11 PM
gfretwell Offline
When I read the comment in the handbook it appears they are saying you can't install a screw shell lamp holder with the intent of using a 2-15 adapter in it. I don't see anywhere where it says you can't have a receptacle and a screw shell in the same device.
The real question might be how can U/L list the screw shell to receptacle devices in light of 410.47
2017 / 2014 NEC & Related Books and Study Guides
Re: NEC Trivia Question??? #100546 12/03/06 12:21 PM
HotLine1 Offline OP
OK, based on the above comments, and that the device is mfg, and it has a UL label, and there is NO NEC Article prohibiting use, it's acceptable.
OK, no winners in our local debate; no one can put a Code cycle on the 'supposed' outlawing.
Thanks to all!
Re: NEC Trivia Question??? #100547 12/04/06 10:08 AM
Ryan_J Offline
Just because something is listed doesn't make it legal.
Ryan Jackson,
Salt Lake City
Re: NEC Trivia Question??? #100548 12/04/06 12:59 PM
Alan Nadon Offline
The current wording in 410.47 is in my 1950 NEC but, the next earlier one I have, 1940 list the different sizes of standard lamp bases. Some time during that ten years the Code changed. (As did much of the World)
Not many places where the combination could be used unless it is on a GFI circuit.
Alan--
Alan--
Re: NEC Trivia Question??? #100549 12/04/06 02:27 PM
HotLine1 Offline OP
OK, 410.47 is again noted, but not the question.
Ryan, yes, we all agree, listing does not make it "legal".
I'm refering to the porcelain lampholder, with the 3 prong recept 'built in'.
Re: NEC Trivia Question??? #100550 12/04/06 09:45 PM
gfretwell Offline
Ryan What you are really saying is just because something is listed doesn't mean it is "approved".
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Trumpy
Trumpy
SI,New Zealand
Show All Member Profiles
Admin 7
264,265 Are you busy
199,223 Re: Forum
188,100 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
