0 members (), 743 guests, and 8 robots.
#100405 11/16/06 07:04 PM
As long as you don't violate your working space does anyone know of any code prohibiting installing a sub panel with a sink 3' to right of it. This is a commercial building inside a copy room
Thanks
Workgear for Electricians
#100406 11/16/06 08:23 PM
Key description is 'commercial'. No there are no restrictions, except for working space clearances
#100407 11/16/06 08:28 PM
Thanks John,
Thats my interpration as well, but I am the minority.
#100408 11/16/06 09:53 PM
You could mount it *in* the sink if you used a NEMA 6P panel! Well, maybe not, it would be hard to get the required working space...
If you use a NEMA 3 panel, I don't see any problems. And even that's probably not necessary.
#100409 11/16/06 11:44 PM
I know of no NEC rule against being near a sink unless this is the bathroom and you can't be in there at all. Just be sure you have working space.
#100410 11/17/06 03:52 PM
Quote"Key description is 'commercial'. No there are no restrictions, except for working space clearances"
What is this key word "commercial" stuff? Please give us a code reference for that.
#100411 11/17/06 05:33 PM
The limitation on installation of panels in bathrooms is only for dwelling units and guest suites of hotels and motels per 240.24(E) '05 NEC.
George Little
#100412 11/17/06 07:34 PM
oops, I get it now. I thought we were trying to say no panels near a sink in dwellings. Of course I knew about bathroom panels in dwellings.
#100413 11/17/06 07:37 PM
George:
A Thank You, from me to you...
