Pool pump motors aren't fed with a GFI breaker, but spa's are, why is that? Do I need to feed an underground aquarium with a GFI breaker? If so, does it have to be fed from the 125a sub-panel, to a 60 amp sub-panel that will control the motors, or just 1 GFI breaker for each pump motor?
The Golden Rule - "The man with the gold makes the rule"
