In case anyone needs more info:
www.lenoxsaw.com/rcshlsw.htm gfii.com/it/brand/sawblades/accessoriescatalog.pdf
(Check p. 9 of the PDF for Remgrit hole saws)
BTW, my foreman taught me the trick of using a carbide grit blade in my sawzall for drywall/plaster work. Beats changing wood blades every 5 minutes, and the wall doesn't flake apart on you.
[This message has been edited by DougW (edited 05-09-2004).]
