I need to know the proper way of bonding an above ground pool. The pool filter is fed thru a 120v 20a GFI receptacle mounted on a post near the filter. The pool filter came with about a 30 inch cord. The pool filter has an external lug on it. Do I run a #8 to the rib of the pool? How would you attach a lug to the rib of the pool? I do not know if the pump is double insulated.
TIA
