I am wiring a home theater and the equipment will be installed in the basement on a rack. The specs call for two 20 amp isolated ground receptacles. The basement is not finished and the rack will be in front of the receptacles. I am not sure if these are required to be gfi protected under the exceptions to 210.8 A (5). I don't think so but I'd like other opinions. Thanks Scott
