So, when do you use non-metallic liquidtite flex vs metallic liquidtite? What situations do your inspector feel are "subject to severe physical damage", requiring the metal armor under the plastic?
Just re-wired an irrigation pump that was a total mess, used metallic type sealtite, as the pump etc are out in the open and I didn'y want the mule deer chewing through the non-metallic flex. Fittings were $ and time to install compared to Arlington's LFNC fittings.
Cliff
