How do some of you set the disconnect at a drilled well. I had one that had a 1 inch threaded opening where the wire was coming out. I ended up getting a 1" X 1/2" reducer and had to use a 8" galvanized nipple to get it high enough to screw a weatherproof bell box on, so it would miss the faucet and pipes coming out of the well. Even though with the cover on the well,though it may not be considered a "wet location", I wanted to use a weatherproof box, just in case the cover got blown off or something ( it was just a fiberglass one). Ended up being there til after dark, working by headlights of van [Linked Image] There was really no room to do much of anything else unless I could have screwed a 90 degree fitting into my 1" X 1/2" reducer, then flexed it around and then down to a box and mounted it on the fiberglass well casing itself. That would have been a bulky looking site, and don't know if it would have worked. Any suggestions? Thanks Steve..
