What is the proper way to bond a residential service entrance installed in conduit? power The power co supplies a meter base with a bonded neutral so if you install the main bonding jumper in the panel that would make the conduit between the panel and meter base in parallel with the neutral and a current carrying conductor.If you use bonding bushings it does the same thing . Just what do you do. THANKS HYPRESS
