Wiring a new house with a Great Room, 18 ft ceiling with wood, owner doesn't want any lights in ceiling. Room approx 20 ft wide, with fireplace. To accent light the fireplace, would it be best to try and use MR-16 lights or something similar on the side walls of the room. Or use some kind of up lighting on the mantel? (fireplace goes from floor to ceiling with stone)
Off the subject, but has anyone ever installed a door jam switch or reed switch for turning on a light when door is opened? If so, do you recall who the manufacture was or where to get this type of switch?
Appreciate any info or insight.
Thanks Again Gentlemen
Mick
