Is anyone familiar with the testing method to check that 25 ohms or less are at the ground rods. Here on L.I., we have a single ground rod as a supplement to the main water pipe. Has anyone used a clamp on style meter to check grounds? Are the 3,4 type terminal testers better?
Thanks
