I suspect there may be 2 factors at play. At 6 digit voltages there is a corona around that wire and there also may be a lot of heat. HV lines are typically overloaded and run pretty hot. The eagles do sit on top of the poles for transmission wires.
[Linked Image from gfretwell.com]
