InSinkErator® Recalls SinkTop™ Switch Accessory for Garbage Disposals Due to Fire HazardRecall Date: March 6, 2018
Recall Number: 18-116
Recall SummaryName of Product:
InSinkErator Single Outlet SinkTop Switches
Hazard: Water can get into the power module, posing a fire hazard.
Remedy: Replace
Consumers should immediately stop using the recalled switches and contact InSinkErator for a free SinkTop switch replacement.
Consumer Contact:
InSinkErator toll-free at 855-215-5695 between 8 a.m. and 5 p.m. ET Monday through Friday or online at
www.insinkerator.com and click on “Safety Notice”, or
www.insinkerator.safetynotice.expertinquiry.com for more information.
Pictures available here:
https://www.cpsc.gov/Recalls/2018/I...for-Garbage-Disposals-Due-to-Fire-HazardRecall Details Units:
About 1,400,000 (In addition, about 28 were sold in Canada)
Description:This recall involves InSinkErator Single Outlet SinkTop Switches. The air activated switch mounts to the sink or countertop and is an alternative to the traditional wall switch for a garbage disposal. The model numbers are 76703, STS-SOSN, 78251 and 74300, and can be found on the back of the power module. InSinkErator is written on the front of the power module. The switches were sold with a chrome, white, or satin nickel button/bezel as an accessory for garbage disposals. Garbage disposals activated by a wall switch are not affected by this recall.
Incidents/Injuries:InSinkErator has received 40 reports of water causing overheating damage to the power module and outlet beneath the sink. No injuries have been reported.
Sold At:
The switches were sold between 2005 and October 2017 at home improvement stores, online websites and through plumbing contractors and outlets for between about $50 and $90.
Manufacturer(s):
Tecmark of Mentor, Ohio
Distributor(s):
InSinkErator of Racine, Wis.
Manufactured In:
United States
