I guess the best would be something like what you see on this page:
https://goo.gl/s9yd5E GFCI (RCD) on each outlet will result in only a local switch off in case of a faulty device, but it may cost some more. (Not mutch more if this page has realistic pricing) Ebay:
https://goo.gl/WNMdTjAs I know the UK system you have pretty heavy fuses, and use smaller fuses in each socket, it should have been the European standard!
Good luck from Norway!
dsk
