If you install a PVC-coated rigid conduit like Reno suggests you'll find that it doesn't sag like PVC does and the coating (inside and out) will protect it from corrosion.
Our plant has the worst environment imaginable for corrosion and the PVC-coated conduit installed 12 years ago still looks like new.
It's a bit more money up front but you'll never have to replace it.
