Scott35:
Mainly at this time just working to use the layout portion of the program to get this project done. I do know you can export as DWG and other file formats but don't know if you can import, have not checked it out at this time.
You can check it out at
http://www.cmhsoftware.com/wirepro.htmand read up on it. There are a few links on the page. You can see the brochure at other details that may answer some of your questions.
Hope this helped.
