Hi, I have a reduced voltage motor starter with the contacts submersed in oil.
I am trying to find oil to add/change, any ideas what oil might be in the starter ? transformer oil ?
Supply house said the oil is obsolete but they can get it in 4 oz containers at $60 bucks each, that will be very expensive
seeing I need 5 gallons.
This is an old Cutler Hammer starter you pull the arm forward to start the motor and when at speed push arm back to run.
Thanks for any help
Dave
