In the same conduit are you allowed to run normal 60hz and also 50hz conductors? as long as they are marked? There is a conduit that was run for equipment that has controls of 50hz. We want to pull #10's through the same conduit for a small water heater, which will be 60hz.
Thanks - SJT
