Nicely done Scott! Also, unlike plumbing you can't see the electric leaking out on the floor and may just sit waiting to be a problem for months , years. For example it is common around here for the electrician to leave a roll of wire for the genreal to install the post light. This results in UF buried 6" under the ground or under the walk. No care is used in the installation and all the knick and kinks don't become a problem till they corrode off a year or more later. Contractor is long gone. I'm not complaining mind you it keeps me busy fixing them.
Ob
