I always worry about lackluster performance most shower trims give.
If the customer can handle the slightly funky standoff of the trim I like to use a Lithonia L3 with wet trim. It's wet rated with an exposed 75W PAR30. Looks a little strange to some though. I have it in my shower, I like a bright, wake you up shower light
As far for other members in here they are right on the spot and I know the last shower trim I have to deal due one ceiling is at 9 foot so I end up leave it open trim but the inspector told me make sure you use the
PAR bulb not the BR rated bulbs.
Now in France that will change a bit here under 8 foot no luminaires are allowed in shower or bathtub area unless it is low voltage verison with RCD { 10ma setting instead of normal 30ma setting } but once you get above the numbers of feet/ meter of height then it will become normal set up.
Merci.
Marc
