Our school board (that I work for) supplies the Fluke T5 to many of our people. Personally I don't like it. However; the reason I don't like it is because I do mostly low voltage work and need a VOM meter 20 times for every 1 time I need a volt/amp tester. If I used it more like a volt/amp meter I'd love it. Bottom line (IMO): real nice unit unless you need ohms to the 1/10th, capacitance (spelling??), & Hz etc more often than volts and amps.
