I would go the partial inspection route, and take lots of pictures to document what shape the job was in when you took over. As far as ethics, I do not see a problem, unless you are friends with the other EC. You are assuming responsibility for any work that is already covered up, if you know the other ECs work is good than you have no worries.
Jimmy
Life is tough, Life is tougher when you are stupid
