He is right, they added "crawl spaces" to the article. So now instead of applying simply to unfinished basements it also applies to crawls.
Apparently to comply with the 2008 code you must now bore holes and run the cabling through the joists or use running boards. You are no longer allowed to staple NM cable to the joists. frown
Errrr WTF?
