I would like to use two 5-pair 110-connecting blocks with both data and POTS. Four pairs of each connector block being used for two data jacks and the two slate pairs to provide two separate POTS lines [phone & fax] in the same location using three 4-pair CAT5e cables, leaving two pair unused. Does this sound as if it would be acceptable or would data interference and crosstalk be a problem.
