How often do you get a service call for a stripped or damaged Plastic wall case / box ? How do you make the repair and how long does it take? Is this a common problem with plastic boxes? I find that most have been caused by the installer using a drywall screw instead of a 6-32 or the plastic becoming brittle and breaking at the support hub.
