WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission (CPSC), MCM International of Eden Prairie, Minn., is voluntarily recalling about 50,000 Black Catâ„¢ electric pressure washers. MCM International imported the pressure washers from a manufacturer in China who installed counterfeit ground fault circuit interrupter (GFCI) plugs on some of the units, without MCM's approval. All of the plugs are labeled "WELLONG"; however, the pressure washers with counterfeit "WELLONG" GFCI plugs appear virtually identical to those with genuine "WELLONG" GFCIs. It will require a professional inspection to identify the counterfeit GFCIs. GFCIs are important safety devices that are intended to protect consumers against shock or electrocution.
Click >>
more info
