HI, WELL YOU CAN USE ANY KIND OF 120 VOLTS DIMMER THAT IS NOT JUST FOR INCANDESCENT , YOU NEED A DIMMER READY TO BE USED WITH INDUCTIVE LOADS, THE DIMMER SAYS IN THE BOX IF IS READY TO BE USED WITH INDUCTIVE LOADS OR WITH TRANSFORMERS OR IF IT SAYS JUST RESISTANCE LOADS ( INCANDESCENTS ) JUT CHECK IF IT SAYS YOU CAN USE WITH TRANSFORMERS ( A TRANSFORMER IS AN INDUCTIVE LOAD ) AND YOU ARE READY, BE AWARE THE DIMMER CONTROLS THE HIGH VOLTAGE ( 120 ) VOLTS OR PRIMARY OF THE TRANSFORMER , THE OUT OF THE TRANSFORMER IS ALWAYS CONNECTED STRAIGHT TO THE BULBS, NEVER THROUGH A DIMMER ( EXCEPT IN INDUSTRIAL OR ESPECIAL CONDITIONS FOR TELEVISION, THEATERS OR OTHERS )BUT NEVER FOR RESIDENTIAL ANY QUESTION JUST LET ME KNOW
LUIS SILVA SANTISTEBAN
(Company Name and Contact info removed)
[This message has been edited by Webmaster (edited 09-26-2004).]
