I just installed a couple of these, and I am not thrilled with them at all. Why, you ask?
Well, when you tighten the wire on the pressure plate, the back of the GFI begins to bulge as the plate tries to twist its way through the cheap plastic on the back. And no, I wasn't overtightening the screw either, I was trying to get it tight enough so that I felt confident that the wire wouldn't slip out. Even with them tightened, and ready to fall apart, the wire could still be pulled out. I didn't have this problem with their older ones that were made in Mexico.
I'm not trying to bash Leviton here, as I've always used their devices, and have great luck with them. However, I dont have much confidence in these GFI's, and will consider using P+S in the future.
BTW, I purchased these at a supply house, not Home Depot. They are monochromatic and have a black case.
Has anyone else had problems with these?
Peter
