Ground Rods: Installation and Hook-Up
by renosteinke - 11/26/22 07:28 PM
Happy Thanksgiving all!
by Bill Addiss - 11/24/22 08:37 AM
Colt Firearms Switchbox
by sabrown - 11/22/22 01:33 PM
Perfect work light?
by gfretwell - 11/22/22 12:48 AM
copper prices where you live and inflation
by gfretwell - 11/21/22 01:52 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 38 guests, and 50 robots.
Previous Gallery
Next Gallery
#219339 05/06/18 09:50 AM
Plug terminals
This morning ,I got a three-phase plug with 6 wire terminals( see pictures), L1 , L2, L3, N/W, Earth, and a "pilot" terminal, I don't know what 's the "pilot" terminal use for , for testing or other purposes ?
7 Comments
Tjia1981 #219361 05/21/18 04:40 AM
Typically to operate a contactor, controlling the supply.
Tjia1981 #219364 05/21/18 10:41 AM
Hi ,geoff, Thank you for your answer
This picture was taken in my workshop , and these three-phase plug mainly used for connecting equipment like water pump , electric welding machine to the AC 380V distribution box on the wall,no control circuit inside the distribution box , and controlling the power supply only by RCD
Tjia1981 #219374 05/23/18 12:24 PM
Well, just not used in your case, and probably has no connection, but that's what it was intended for if needed.
Tjia1981 #219377 05/24/18 12:06 PM
Perhaps an indicator light, or a monitoring device?
Tjia1981 #219459 07/16/18 10:03 AM
If it's a CEE Standard plug, the Pilot contact is for operating a Contactor, so the plug contacts don't wear off when connecting or disconnecting under load.
See here, chapter 4.1 https://en.wikipedia.org/wiki/IEC_60309
Tjia1981 #219460 07/18/18 10:01 AM
Hi, andey. This is a "MENNEKES" plug with made in Germany, I have seen the fully detailed explanation about the "pilot" contact on wikipedia website, thank you for your help!
Tjia1981 #222002 11/10/22 10:07 AM
It’s the first time I see a plug like this! Thanks for the explanation! Now I will be more aware of the types of plugs that exist.
I use only the regular ones in my house, unfortunately. It would be cool if the plugs looked more interesting than they are now. Why are the US plugs the way they are? I think the European ones look cooler.
I have a few amazon smart plugs in the house too. They help me control electricity consumption and turn on and off devices via wi-fi. These are some of the best household devices I’ve ever purchased. If you are lazy and don’t want to get up whenever you need to unplug something, then it’s for you.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
dougwells
dougwells
kamloops BC Canada
Trumpy 3
NORCAL 3
300,230 Are you busy
229,955 Re: Forum
214,778 Need opinion
