ShoutChat Box
From an outsider- How does tipping work?
by NORCAL - 01/17/21 05:26 AM
Can I ask for your input?
by electure - 01/16/21 07:04 PM
Ground fault remover :-)
by NORCAL - 01/16/21 10:29 AM
Photo Editing Software?
by grich - 01/13/21 11:18 AM
Happy New Year Folks!!!
by Trumpy - 01/04/21 05:46 AM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 13 guests, and 15 spiders.
Previous Gallery
Next Gallery
FPE in Germany pt.2 #220378 12/09/19 01:46 PM
3 Images
andey Offline OP
FPE in Germany pt.2
Uploaded for another forum thread
4 Comments
Re: FPE in Germany pt.2 [Re: andey] #220763 04/29/20 11:22 AM
WaterIngress Offline
Thank you for posting this. Looks like German FPE breaks have a magnetic trip coil not found in the US versions.
Re: FPE in Germany pt.2 [Re: andey] #220770 04/29/20 06:55 PM
sparky Offline
Can you cite an example of mag trip coil for viewer reference please?
~S~
Re: FPE in Germany pt.2 [Re: andey] #220771 04/29/20 07:18 PM
Here is an example inside an EU breaker (labelled as a solenoid):
https://www.engineersgarage.com/sit...ageupload/4214/Internal-Parts-of-MCB.jpg
Re: FPE in Germany pt.2 [Re: andey] #220853 06/23/20 06:29 AM
andey Offline OP
That is correct, Wateringress. The coil in my photo is on the left side, hidden under the sheet metal fin.
I'm not sure about the whole EU, but all breakers in Germany, since many decades, have these two working mechanisms. The bimetal strip to act time-delayed in overload condition, and the coil for instant trip in short circuit situations. There's different trip curves but the most common curve is "B" where the instant trip will start working at 3 to 5 times the nominal current.
With the most common breaker for regular outlets being B 16 Amp, the fault loop impedance must be low enough to have at very least 80 Amp flow in case of a short, to trigger the instant trip. This is also something the contractor needs to prove by measurement with a special meter.
A common value for the available short circuit current in a regular panel of a German appartment is around 300-2000 Amp. Depending on the distance to the transformer and wiring. So if the wire from the breaker to the outlet is not too long, and terminations are good, you easily make the 80 Amp plus some functional reserve.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
sparky66wv
sparky66wv
West Virginia
Show All Member Profiles
Trumpy 15
NORCAL 10
273,973 Are you busy
207,727 Re: Forum
195,438 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
