ShoutChat Box
HVDC Greece to Crete
by gfretwell - 08/06/20 02:28 AM
Electrician and Telecomunications
by tonymackers478 - 08/05/20 05:46 AM
310.15 (B) 7 Feeders
by HotLine1 - 07/31/20 02:29 PM
What would be the ideal solution?
by Fleppin - 07/21/20 12:42 AM
NESC question
by gfretwell - 07/16/20 04:17 PM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 13 guests, and 14 spiders.
Previous Gallery
Next Gallery
Plug terminals #219339 05/06/18 10:50 AM
Tjia1981 Offline OP
Plug terminals
This morning ,I got a three-phase plug with 6 wire terminals( see pictures), L1 , L2, L3, N/W, Earth, and a "pilot" terminal, I don't know what 's the "pilot" terminal use for , for testing or other purposes ?
6 Comments
Re: Plug terminals [Re: Tjia1981] #219361 05/21/18 05:40 AM
geoff in UK Offline
Typically to operate a contactor, controlling the supply.
Re: Plug terminals [Re: Tjia1981] #219364 05/21/18 11:41 AM
Tjia1981 Offline OP
Hi ,geoff, Thank you for your answer
This picture was taken in my workshop , and these three-phase plug mainly used for connecting equipment like water pump , electric welding machine to the AC 380V distribution box on the wall´╝îno control circuit inside the distribution box , and controlling the power supply only by RCD
Re: Plug terminals [Re: Tjia1981] #219374 05/23/18 01:24 PM
geoff in UK Offline
Well, just not used in your case, and probably has no connection, but that's what it was intended for if needed.
Re: Plug terminals [Re: Tjia1981] #219377 05/24/18 01:06 PM
HotLine1 Offline
Perhaps an indicator light, or a monitoring device?
Re: Plug terminals [Re: Tjia1981] #219459 07/16/18 11:03 AM
andey Offline
If it's a CEE Standard plug, the Pilot contact is for operating a Contactor, so the plug contacts don't wear off when connecting or disconnecting under load.
See here, chapter 4.1 https://en.wikipedia.org/wiki/IEC_60309
Re: Plug terminals [Re: Tjia1981] #219460 07/18/18 11:01 AM
Tjia1981 Offline OP
Hi, andey. This is a "MENNEKES" plug with made in Germany, I have seen the fully detailed explanation about the "pilot" contact on wikipedia website, thank you for your help!
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
mxslick
mxslick
Atomic City, ID USA
Show All Member Profiles
BigB 3
268,494 Are you busy
202,919 Re: Forum
191,312 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
