This thread raises an interesting question about a wet location rating.
Normally any underground location is considered a wet location.
But if you have a heat source that can actually heat the wire up to 125C, then it is quite unlikely that the wire will actually be wet
In essence, the wire will be baked dry by the light.
So is this a wet location or not? It might very well be wet when the light is off, but dry by the time the temperature exceeds the wet rating of the wire
-Jon
