0 members (), 404 guests, and 25 robots.
#99512 05/27/06 12:59 AM
V
victor Offline OP
Hi I would like to know where in the NEC talks about using liquidtight conduit to connect a dry type transformer because fo vibration. Thank you
#99513 05/27/06 07:41 AM
Welcome to the forum victor.
You will not find anything in the NEC requiring liquidtight conduit to be used to connect a dry type transformer because of vibration.
It is just a design choice buy the installer.
#99514 05/27/06 03:03 PM
I'll go a bit farther...
True, the NEC does not address the matter. However, NECA standards document the use of flex at transformers as "trade practice", or good workmanship.
That aside, I noticed recently that some transformers have internal rubber mounts, so the piping actually does not connect to the part that vibrates.
I still like to see flex at the case, though. Old habits die hard.
#99515 05/30/06 10:40 PM
V
victor Offline OP
hi thank you for your reply, where can I get a copy of NECA stating the use of liquid flex as a good workmanship. Thank you
