516
17
At what point does the OSHA regulation stop? After the house is purchased and is now someone's home and no longer a construction site? Or what happens on a remodel? Is the portion of the house not being worked on ok to use a carpet iron without GFI protection while the carpet installer in the next room which is part of an addition must use GFI protection?
OSHA 'stops' when someone is not being paid for the work they are doing.
What I am trying to say is that OSHA only applies to people doing a job they are employed at.
A while back OSHA was talking about coming into the homes of people who work from home, that idea was rejected.
OSHA derives it's authority from that part of our Constitution that gives the Feds the sole power to "regulate interstate commerce."
"Interstate commerce" has been understood by our courts to include business large enough to "affect interstate commerce." How large is this? Large enough that rulings have applied the Wage & Hour Act. If I remember correctoly, that would be any business, or job, with a value of $250K in a year.
Which is why the original OSHA avt also gave the states strong incentives to create their own state "OSHA" offices. So a smaller business could very well be covered by local rules, while technically exempt from federal rules.
Posts: 7,382 Likes: 7
OK, lurking & silent till now... Iwire has all his ducks in a row with this IMHO.
What we enforce here is: Construction GFI required Renovation areas, same Additions, same Comm, Ind, retail, resi....all treated the same
"unsafe" conditions (in AHJ's determination) require corrections. Now that includes lack of GFI, incorrect 'temp' lighting, etc.
I cannot, nor will not speak for 'others' or 'all', but that's how it's done in my areas, both as an EC and AHJ
I hear others concerns regarding the scope of the jobsites, and the other trades and their practices, but we (EC's) have to cover our butts, right???
BTW, the OSHA 'boys' can get REALLY expensive with violations! GFI's are a good investment!
I find it curious, all this hair-splitting over a $10 widget.
I am also surprised at the absolute lack of interest in repairing the faulty equipment discovered through using that widget.
I can't speak for others... but if my tool was tripping the GFI, I'd get it fixed (or replaced) pronto.... no sense in waiting for smoke to leak out!
Reno: Basically, you just said what I'm thinking, but didn't 'say' in so many words
$10 GFI vs a $$$$$ fine, what's the sense??
Posts: 9,931 Likes: 34
I don't think there was a question when we were talking about temporary wiring or early construction phases. I guess the real question is when it is final trim, punch out or warranty/repair work in finished buildings. Why is a contractor's drill any more dangerous than the customer's when it is used in the living room?
OSHA covers any size business that has employees. No area is actually 'exempt' from the Federal OSHA, what you can have are local rules that meet or exceed OSHA. So at a minimum you must meet the Fed standards. I agree with both Reno and Hotline that the price of the GFCI be it installed or in a cord set is insignificant compared to the fine. Why is a contractor's drill any more dangerous than the customer's when it is used in the living room? Greg I have asked that many times and I think it comes down to this. OSHA is interested in workers safety, the statistics show workers getting electrocuted. That being the case it is not big jump for them to simply say workers using portable tools shall have GFCI protection. They might even want homeowners have to have the same protection as well but OSHA lacks the authority to enforce that.....Thankfully... JMO, Bob
you install a gfi for other trades to use. Who says the GFI works correctly?? and why would want that liablity??
First let me say I am not trying to push these rules on anyone, I am just passing on what I was taught in OSHA classes and electrical safety classes. you install a gfi for other trades to use. Who says the GFI works correctly?? and why would want that liability?? OSHA requires the testing that the manufacture instructs are to be performed and a log of the tests kept.
