Tom, we are now talking about apples and oranges. There are no requirements for the installation if it is hardwired but only where a receptacle is installed do you have requirements.
IF a receptacle is installed,
then the homeowner
is likely to replace the equipment and rules are required. You are not required to install a receptacle so nothing has changed; however, if you install a receptacle, these are the rules. I fail to see the problem with this, you have a choice.
Charlie Eldridge, Indianapolis,
Utility Power Guy[This message has been edited by CharlieE (edited 10-29-2004).]
