373
12
I too use a cordless drill also for the same resone my wrist gets real sore if i only use a screw driver and I have both a dewalt and a fire storm that dont have the two speed gears for drilling and heavy torking I use the dewalt but for fine slow or position of the blade i'll use the fire storm its easer to control i've also worked up a rootine when i'm pluging a switching and a lot less mastakes by just useing my strippers and going through the house putting everything I can on the wirers wrapping the grounds and or hot/neutrals then I just come back and zip everything in with the fire storm like a little production line I found that I could move faster beween the openings then changing tool in my hand a standerded three bedroom house now takes me about 2.5 hours with about 50 openings to plug and switch but I do know this doesent work for every one Also I found a phillips bit that doesent slip as much its called a drywall ice bit by valmont and use square drives as much as posable
[This message has been edited by hurk27 (edited 05-15-2002).]
Be Fair, Be Safe Just don't be Fairly Safe
