#9665 05/08/02 08:47 PM
Anyone know anything about these? Power requirements would be helpful. I don't have a specific model unfortunately. I am wondering what kind of amperage do they draw.
#9666 05/10/02 07:20 PM
They are a real PITA for both the electricians and Plumbers.
The biggest problem is getting the rough-in in the right position. Even when the boxes are exactly placed with the template you are at the mercy of the plumbers for the exact location of the fixture. Fortunately this is really the plumber's equipment and it's his problem.....but it still can look bad when everything doesn't line up properly.
The power is 24vac. The transformer is provided with the flush kits. (plumbers equipment) The amp draw is negligible. Depending upon the size of the transformer, one transformer can power several flush valves.
GJ
#9667 05/10/02 09:02 PM
Scot,
I did assume that you were asking about powered flush valves...........
and not the foreign models with the heated seats! [Linked Image]
#9668 05/11/02 12:16 AM
Heh heh...PITA... That's the name of my puppy! (For the same reason).
[Linked Image from users.stargate.net]
-Virgil
5 Star Inspections
Member IAEI
