#9658 05/08/02 08:26 PM
I need a source for communication cabling J-hooks. I get a blank stare from the local electrical distributors. It's just a heavy wire hook to keep the cabling up out of harms way above the suspended ceiling.
Who makes these things???
TIA
GJ
#9659 05/08/02 08:31 PM
There are many different companies that make these. One is by Arlington, its called "The Loop". Another is the "Cable Cat". I am ooking right at them now in a mailer from a distributor. If I was a little more computer literate I would scan the picture and send it to you but.....
#9660 05/08/02 08:41 PM
Scott,
Thanks for the fast response. I spent some time looking online and found that Caddy also makes them. The local distributor carries Caddy and should be able to get them.
I HATE it when I have to educate wholesalers about their own product lines. [Linked Image]
GJ
#9661 05/09/02 05:12 AM
Been training and retraining them for years. The guys just scatter when I come through the door with a Square D Digest in my hand. I have to fill out the order info to get any Teleemechanique contactors, the little compact stuff. They just don't have a clue.
Lighting the way
#9662 05/09/02 05:52 AM
Try http://www.phonegeeks.com/drivrinforat.html.
Never bought anything from these guys, so I don't know how they are to deal with.
They call them "drive rings"
#9663 05/11/02 09:08 PM
Uhm, er, the formal 'old bastard' term for these is bridle rings.
Here is an example of two threaded versions. http://www.erico.com/erico_public/pdf/Engineering/Fixing/Electrical/brringovr.pdf
There is also a nail-type version.
Gee I feel old.
#9664 05/11/02 11:54 PM
Bjarney,
A drive ring and a bridle ring are two different things.
Any old phone installer could tell you that you used bridle rings in locations lower than 6-7 feet, because a bridle ring does not have the projecting pin that the drive ring has.
Cliff
