#95570 09/22/05 10:03 PM
All in favor of eliminating pre-punched knockouts on anything painted grey- raise your hands!
#95571 09/23/05 06:47 AM
Hand up.
An alternative in many cases is to use reducing bushings with locknuts inside and outside.
An extreme gripe of mine is that small motors come with a 3/4" KO already knocked in them, heavily painted. It's a regular thing to find them with a 1/2" sealtite connector hanging by the conductors, RE washers floating around and a locknut floating on the inside :down:
#95572 09/23/05 10:56 AM
What is with you guys? I'll bet that at least 1/2% of the times I've come across reducing washers, they have provided a good ground.
I hate those things!
#95573 09/23/05 02:03 PM
.05% Wow that's bad. Did you mean 50%.
I'm sorry cheap shot but I'm a cheap shot artist. [Linked Image]
George Little
#95574 09/23/05 02:41 PM
George, you mean .5%? (cheaper shot)
#95575 09/23/05 03:00 PM
Found this picture on another site and thought it would say it all.
[Linked Image from nachi.org]
Thank you, Joe Tedesco
[This message has been edited by jw electric (edited 09-23-2005).]
After three trys I get it right, YEA!!
Mike
#95576 09/23/05 03:12 PM
First off, reducing washers are heavily used in my side of the biz. (Cinemas) Mainly on the flex for the DC leads to the Xenon lamp, though. Seems that the manufacturers of that equipment can't get on the same page and design a standard KO size for a given lamp type.
And did any of you catch the doublespeak in this from the UL white book? (Bold emphasis is added by me.)
GROUNDING
Metal reducing washers are considered suitable for grounding for use in
circuits over and under 250 V and where installed in accordance with
ANSI/NFPA 70, ‘‘National Electrical Code.’’
Stupid should be painful.
#95577 09/23/05 07:14 PM
It was a test Greg to see if you were watching.
George Little
