1 members (Scott35), 37 guests, and 12 robots.
#95429 09/13/05 09:36 AM
When installing NM cable in a dwelling unit, do the inspectors require metal wiring methods in CA returns?
George Little
#95430 09/13/05 10:43 AM
See 300.21(C)
Exception: This section shall not apply to the joist or stud spaces of dwelling units where the wiring passes through such spaces perpendicular to the long dimension of such
spaces.
#95431 09/13/05 01:00 PM
Joe- the issue that seems to have come up is the wording "passing through" versus "terminating in" the CA. If it passes through the CA perpendicular to the long dimension I don't see a problem but when you start installing boxes it's debatable. I'm curious how this forum feels about it.
George Little
#95432 09/13/05 01:20 PM
I think the code prohibits it. I also think that it is a silly prohibition. The IRC allows anything, other than gas piping, to be installed in a plenum. For example, I could run a 4" ABS lengthwise through a plenum, and that wouldn't matter. I can't do this with 14-2 NM cable, however. [Linked Image]
Ryan Jackson,
Salt Lake City
#95433 09/13/05 02:07 PM
The "passing through" language is meaningful.
When you install a box in a return plenum, the box becomes a return air register. It is just like the dumb idea of PCs "breathing" through the diskette drive.
They end up packed with dirt.
In a dwelling that dirt could be combustible.
BTW a Florida guy would ask why you are "returning" cold air? That is the supply side. [Linked Image]
#95434 09/13/05 07:57 PM
gfretwell,
What about the "hot" water heater?
#95435 09/13/05 08:52 PM
We keep it outside.
#95436 09/14/05 07:48 AM
Why does hot water need to be heated, anyway?
#95437 09/14/05 09:09 AM
Hot water needs to be heated for cleaning dishes as in a restaurant. They are called booster heaters and are used to increase the temperature to a higher level to meet health department requirements,
How did we migrate to this from derating NM cable?
George Little
#95438 09/14/05 11:16 AM
As luck would have it, there is a new pic in the Photo forum that illustrates this issue.
