532
19
When installing NM cable in a dwelling unit, do the inspectors require metal wiring methods in CA returns?
George Little
See 300.21(C)
Exception: This section shall not apply to the joist or stud spaces of dwelling units where the wiring passes through such spaces perpendicular to the long dimension of such spaces.
Joe- the issue that seems to have come up is the wording "passing through" versus "terminating in" the CA. If it passes through the CA perpendicular to the long dimension I don't see a problem but when you start installing boxes it's debatable. I'm curious how this forum feels about it.
George Little
I think the code prohibits it. I also think that it is a silly prohibition. The IRC allows anything, other than gas piping, to be installed in a plenum. For example, I could run a 4" ABS lengthwise through a plenum, and that wouldn't matter. I can't do this with 14-2 NM cable, however.
Ryan Jackson, Salt Lake City
Posts: 9,931 Likes: 34
The "passing through" language is meaningful. When you install a box in a return plenum, the box becomes a return air register. It is just like the dumb idea of PCs "breathing" through the diskette drive. They end up packed with dirt. In a dwelling that dirt could be combustible. BTW a Florida guy would ask why you are "returning" cold air? That is the supply side.
gfretwell,
What about the "hot" water heater?
Why does hot water need to be heated, anyway?
Hot water needs to be heated for cleaning dishes as in a restaurant. They are called booster heaters and are used to increase the temperature to a higher level to meet health department requirements,
How did we migrate to this from derating NM cable?
George Little
As luck would have it, there is a new pic in the Photo forum that illustrates this issue.
