Take a look here:
https://www.electrical-contractor.net/ubb/Forum16/HTML/000239.html Edited to add:
Hope it isn't much above 120 v at 20 amps if you do this mistake.
Rated circuit ampacity won't make you safer in that case. It is the available short circuit current and impedance of the system wiring that makes a difference. I have personally witnessed the effects of
accidental shorts on so-called 120/20 circuits in cinemas served by a nearby network transformer..the resulting arc flash would have caused serious injury to anyone nearby. The devices in question were totally destroyed. Those facilities all had "Series Rated" panels at all locations.
To twist a common phrase here, "It's not the size of the dog, but the size of the bark."
[This message has been edited by mxslick (edited 09-21-2005).]
