Foestauf:
"and as to working hot with a helper sure sounds nice but if less then 480/277 volts not really considered dangerous...since we are electricians and take every precaution not to ground ourselves while working hot(gloves,hot blankets,good insulated tools,ect).
like i tell my guys, be the bird on the wire NOT the squirell on the pole....fried crispy style."
Where is that in the OSHA/POSHA/NESC books??
And, like I said above....a little respect, may go a long way. If you know the guy wants stickers, put 'em on before he gets there; not when he tells you. I cut guys slack to 'fix' something while I go thru the inspection, as long as it's OK when I'm ready to leave. Now, if they have devices/plates/fixtures missing, oh well, a "Not Ready" fail.
Sometimes attitude helps a lot!
That's it, I'm done!
